Multifunction DAQ
Adaptor PCI 6013- PCIe 6351
I have an equipment with PCI 6013 and an old version of Diadem 9 (2003) and i want to change it with another PCIe 6351 and Diadem 2019.
Can i find an adapter to use the plug from 6013 and connect to 6351?
Thanks!
Ciprian
(765 Views)
What external accessory board did the PCI-6013 connected to?
Essentially you need a SCSI to VHDCI cable listed here - https://www.ni.com/en/support/documentation/cable-accessory-guide/daq-multifunction-i-o-cable-access...
Santhosh
Soliton Technologies
(743 Views)
PCI 6013 is connected to an old PC with XP where I have an old version of Diadem from 2003, I made an upgrade for the script in Diadem 2019 on another PC with W11 who has a PCIe 6351.
Problem is the plug from the loadcell of the equipment is D-Sub 68 pins female and if I buy cable SHC68-68-EPM it has also female at one end ( the other end is okay , it fits the VHDCI with PCIe 6351). So i need a D-sub adaptor SCSI male-female, or an SHC68-68-EPM male-male.
Ciprian
(731 Views)
