Hello;
You will probably need a combination of the digital board you have with a counter board.
Then you can catch the intial time that the application starts, and then to count the PCKL pulses with the counter. You will need to stop the counter when the pattern you are looking for is matched (you can configire the 6534 board to generate a pulse when the pattern is match, and use that pulse to stop the counter).
Since you know the TimeBase that the counter is using, to have the accurate time that the pattern was matched, you will need just to multiply the number of pulses the counter registered by the timebase, and add the initial time. I suggest you to work with the 660x counter board for that purpose.
Hope this helps.
Filipe A.
