Multifunction DAQ
Acquisition trigger start and stop - any new methods for DAQmx 8 and M series devices?
There hasn't been any good way that I've seen to start an acquisition on a digital edge and then stop the acquisition on the opposite edge of the same digital line. Has DAQmx 8 and/or M series devices changed that?
George
(3,558 Views)
Actually, there has been a way to do this since DAQmx 7.0.  Although the hardware doesn't support a true stop trigger, you can use a reference trigger to effectively do what you want with some minor caveats.  Check out this thread and see if this solution will work for you.
(3,548 Views)
Thanks. I did see that and actually have it working. Even though the explanation is good I'm still a little fuzzy on how it actually works. I was just wondering if there was anything new to allow you to do it in a more straightforward manner.
George
(3,544 Views)
Hi George,
This KnowledgeBase article goes into details about how this works.  At the moment, there aren't any new features that allow you to implement a stop trigger differently though.
Thaison V
(3,533 Views)
