Multifunction DAQ
Acoustic Emission DAQ need
Hi Jason, I am following this and I hope you will share how it worked out for you.
I am also in academia and looking into AE as an additional tool to use in thermal analysis.
Cheers,
Serge
Message 11 of 17
(1,949 Views)
wish I could. I didn't pull the trigger on the sensor. The cost was pretty high. It was going to cost me a $3k and up to use it. I bit expensive for something I'm only going to use in the future.
best of luck
jason
Message 12 of 17
(1,944 Views)
Hi, Jason,
Just want to follow up if you eventually end up with Physical Acoustic's AE sensor and NI hardware. Our lab got one recently but I am having a hard time reading valid signals from the PA's amplifier.
Message 13 of 17
(1,071 Views)
What hardware are you using?  type of cables & length?  PA is using what I call a propriatary powering system  ...
(my crystal ball show impedance missmatch...  However, my crystal ball is unreliable, as it too often falls off the table unexpectedly 😉 )  the mouting could also be of great influence.
Greetings from Germany
Henrik
LV since v3.1
Message 14 of 17
(1,057 Views)
I am using PA Nano-30 and PreAmp One (5V), this combination is recommended by the PA sales. Cables are BNC to BNC cables (1m), which came together with the sensors/DAQ.
What does "a propriatary powering system" refer to? The PA is not compatible with general DAQ?
Liwen
Message 15 of 17
(1,049 Views)
I don't know what you are expecting.
The transferfunktion of your sensor is ..well.... a little up and down ... yours will be bit different, see your calibration protocol
Nano30__39121.1578578869.1280.1280
What data aquisition do you use?
The  output of the PreAmp One expects a 50 Ohm BNC cable and a 50 Ohm input impedance at the DAQ.
(and schould be powered by via USB, the preamp will power the sensor ) ...
Henrik
LV since v3.1
Message 16 of 17
(1,036 Views)
Thanks for the reply, you can find my post about the setup here.
Basically I mounted the sensor on a stationary surface and wanted to do a tapping test, but I couldn't see any vibration signal when I tapped the surface.
Message 17 of 17
(1,021 Views)
