Multifunction DAQ
Accessing and Acquiring Data from PXI-7854R without using LABView
I am using Reconfigurable I/O PXI 7854R in a PXIE-1078 Chassis. I am using Windows 10.
I am trying to use 7854R without using labview for data acquisition. I am looking for some APIs like the Python API for DAQmx which is compatible for 7854R. Any support in this would be appreciated.
Message 1 of 10
(1,536 Views)
My 5-minute search brought these up, hope they point you in the right direction.
https://nifpga-python.readthedocs.io/en/latest/
https://github.com/ni/nifpga-python
Santhosh
Soliton Technologies
Message 2 of 10
(1,503 Views)
Thank you for the reply. I have gone through the documents.
Can you please confirm if I would require LabView Software to acquire data every time when using the FPGA Interface Python API.
I Understand  that LabVIEW FPGA will generate bitfiles (.lvbitx). Will Labview be required once generated?
Message 3 of 10
(1,486 Views)
My understanding is that you generate lvbitx files using LabVIEW and you can use Python APIs to control the FPGA later on.
Unfortunately, I am a LabVIEW user and could not confirm on Python side. If you do not get an appropriate reply from other forum members it would be best to reach out to NI Support to get a confirmation (btw, you need SSP to get support).
Santhosh
Message 4 of 10
(1,478 Views)
LabVIEW is only required for creating the .lvbitx file. The python API interacts directly with the drivers to talk to the device, it doesn't go through LabVIEW.
Once you have a bitfile that works for what you are trying to do, then it's fine to remove LabVIEW from the machine.
Message 6 of 10
(1,454 Views)
Hello Santhosh,
Sure, will look into the possibilities and get in touch with NI if needed. Thank you for the support:)
Message 7 of 10
(1,448 Views)
Hello Terry,
Thanks for the support. I have gone through it and got the right path to proceed 🙂
Message 8 of 10
(1,444 Views)
Hi Michael,
Thanks for the confirmation. I have a few more doubts regarding how to proceed in this. I would like to Acquire data from analog, digital and PWM pins. Can you please guide me with some Example codes on how to acquire data using 7854R with the FPGA Python API.
Also we have a .lvbitx file which was generated some time ago. Can i reuse the same file with the Python FPGA API. If yes, let me know how to use it.
Thanks in Advance for your Support!!
Message 9 of 10
(1,439 Views)
I would recommend looking at the examples that R Series installs within the LabVIEW folder here:
<LabVIEW Folder>\examples\R Series\Basic IO
as a starting point.
Existing .lvbitx files will most likely work with the Python API, but we only officially have tested with ones created with LabVIEW 2016 and later.
Message 10 of 10
(1,382 Views)
