Multifunction DAQ
Accessing all 4 Analog Outputs on PCIe-6323 using a single terminal block?
Hello NI Community,
I am designing a hardware setup using an NI PCIe-6323 for an auditory research experiment. My application requires 4 Analog Outputs (AO 0 through AO 3) for multi-channel acoustic stimulation and 2 Analog Inputs (AI 0, AI 1) for recording microphone signals.
According to the PCIe-6323 pinout diagram:
  • Connector 0 carries AO 0, AO 1, AI 0, and AI 1.
  • Connector 1 carries AO 2 and AO 3.
Since the analog outputs are split between both 68-pin VHDCI connectors, connecting a standard terminal block (such as a single BNC-2110 or SCB-68A) to Connector 0 only grants access to AO 0 and AO 1.
Is there any NI accessory, splitter/Y-cable, or recommended routing solution that allows accessing signals from both Connector 0 and Connector 1 into a single terminal block, avoiding the need to purchase two separate terminal blocks?
Thank you in advance for your help!
(615 Views)
Accepted by topic author bemarcen
No, there isn't such an accessory.
You can create a custom breakout board with two connectors and you need to wire both connector 0 and 1 to the board.
Santhosh
Soliton Technologies
(568 Views)
