08-04-2026 10:48 AM
Hello NI Community,
I am designing a hardware setup using an NI PCIe-6323 for an auditory research experiment. My application requires 4 Analog Outputs (AO 0 through AO 3) for multi-channel acoustic stimulation and 2 Analog Inputs (AI 0, AI 1) for recording microphone signals.
According to the PCIe-6323 pinout diagram:
Connector 0 carries AO 0, AO 1, AI 0, and AI 1.
Connector 1 carries AO 2 and AO 3.
Since the analog outputs are split between both 68-pin VHDCI connectors, connecting a standard terminal block (such as a single BNC-2110 or SCB-68A) to Connector 0 only grants access to AO 0 and AO 1.
Is there any NI accessory, splitter/Y-cable, or recommended routing solution that allows accessing signals from both Connector 0 and Connector 1 into a single terminal block, avoiding the need to purchase two separate terminal blocks?
Thank you in advance for your help!
08-06-2026 12:48 AM
No, there isn't such an accessory.
You can create a custom breakout board with two connectors and you need to wire both connector 0 and 1 to the board.
