Multifunction DAQ
Accessing PCI-6220 under Agilent VEE
Dear Uli,
Your code works well.  I modified it to take data vs. time with my DAQPad 6015.  Creating the task in MAX is definately much easier than trying to define it in VEE.  One thing I've noticed is that if I run my code once it works fine.  If I run it again, it tells me the task is invalid error -200088.  If I exit out of VEE and load the program again it runs just fine, then fails again though sporadically giving the error "invalid task."  I've tried several work arounds for this, like adding the command "DAQmxIsTaskDone" but it doesnt help, or I'm not using it correctly.  Do you have any suggestions?
Darren
Message 11 of 12
(2,017 Views)
Hi Darren,
we do have the same problem if whatsoever goes wrong and the program stops/hangs. Then we have to close VEE and reopen it.
However, when it executes the planned way, namely stopping the task, clearing the task and deleting the library, it does not happen and we can rerun the program again correctly.
Message 12 of 12
(2,011 Views)
