07-15-2007 06:22 PM
07-30-2007 06:03 PM
I bit the bullet and decided to use the API that comes with the software distro than write my own driver for the two cards.
I do have one question, though. I manipulated writeDigPort.c to write out a different value. Checking a break-out box with a meter, I found that sure enough, it worked. All I changed was to Port 11 and writing out the value 0x1.
Now when I use the same configuration (Port 11) to read the value back out via software, by making the required changes in readDigPort.c, I always get 0xFF.
Any ideas where I may be going wrong?
