What I need to do - using a PCI-1611E - is output an analog waveform for a ceratin length of time, wait, and then read in an anolog signal. The system needs to work in the millisecond ranges, and the triggering needs to be detailed. If anybody can give me an idea of how to go about this I would be most grateful.
The actual device is part of the e-series range, it is a PCI version hence the specification of PCI - you'll find it under NI 6111E - I'm afraid my fingers ran away with my typing before. Also the manual that ships with it describes it as a PCI-6111E. The other information I should have mentioned was that I'm using LabVIEW to program my application.
