Multifunction DAQ
AO AI synchronization with non-regeneration
 I'm working on a program to simultaneously generate and acquire signals. Both operations are carried out continuously. The acquisition part is standard and the generation is in non-regeneration mode, because the signal is updated every period. Both operations are controlled by the same while loop. The program is fairly similar to the "Multi-Function-Synch AI-Read Dig Chan.vi".
The sample rate is different for the 2 operations. For the 2 operations to be synchronised and to not miss any data, is it correct that the following condition has to be verified :
# of samples read / generation sample rate  =  # of samples written / acquisition sample rate
Is this enough for the program to work properly, or I have I missed something ?
I have a PCI-6221 (37 pin) card and Labview 8.0.
(4,001 Views)
Hi Scalpas,
Please check the "Multi Function Synchronization" of the following link
https://www.ni.com/en/support/documentation/supplemental/21/m-series-synchronization-with-labview-an...
Best Regards,
Faris
Bueller
(3,981 Views)
Hi Faris,
Thanks for your answer. I've read this tutorial, but it doesn't include continuous generation and non-regeneration.
(3,978 Views)
I really can't confirm your first question unless you  post a screen shot of your code, or the code itself.
Faris
Bueller
(3,959 Views)
I was a bit confused when I wrote my first message, but I've played around with the various timing parameters and I think I've worked everything out.
Thanks for your help !
(3,920 Views)
