Multifunction DAQ
AC test of PCI NI 6289
I am performing AC test on the NI 6289; i want to do the FFT testand sine3fit test.
I use the AC calibrator DATRON Wavetek 4707 as function generator; I acquire a waveform signal nearly at full scale with a frequency evaluated to the formula fs=j/M*fc (fs: signal frequency, M number of points, fc:sampling rate; J and M relatively prime) to acquire an nteger number of period. Neverthless i am not able to measure more than 70 dB (~12 bit). I always note a spectral leackage effect around the main harmonic.
Is it a problem of jitter? or do you think i do some errors in my tests?
Do you have further suggestion?
Thanks a lot for you help
Giovanni
(4,473 Views)
could you give me further information about your measuring?
Do you aquire data with labview and then communicatin with teststand?
(4,449 Views)
I acquire the data on the PC, through Labview; then i perform the tests in labview or in Matlab; the test follows the satndard IEEE 1057 1994.
After a further investigation, i see that the non linearity (2nd, 3rd, 5th and 7th harmonics) and a small effect of  spectralleackage decreases the performance; at this precision i neoted that a point on the period cycle of the sine wave makes difference.
Any usefuyl suggestioon is welcome
Thanks a lot,
Jiuan
(4,445 Views)
What do you mean by an inability to get more than 12-bits of resolution? How are you verifying that? Can you try using any normal routines in LabVIEW and get the same information?
Are you sure that your hardware isn't defective?
(4,429 Views)
I do a very simple analysis
I acquire the signal and I do the FFT;
then i evaluate the Noise Power and signal power. by the SNR I calcualt the ENOB
SNRdb = 6.02*ENOB+1.76
do you know special function in Labview for doing this?
Anyway,  As i see sporious harmonics, i was wondering about the goodness of the PGA that is mounted on the board.
did you do a similar test? On the NI datasheet, the THD and the SNR is not specified.
Otherwise i have to think thet the calibrator is not adpt, but form the datasheet, it seems pretty good
Thaks a lot,
Jiuan
(4,419 Views)
my Customer wrote me this recently:
Any ideas?
(4,414 Views)
