Hi Jomu2015,
That's very odd, that the inputs are accurate on some channels, but not on others. Are you sure that the device is outputting the correct currents? That would be the first thing that I would check. Let us know whether the measurements match what the 9208 reads, or what the device claims it's sending out.
Here's a good tutorial on how to measure current using a multimeter, if you're not sure: Current Measurement Tutorial.
Kathryn K.
Technical Support Engineer
http://ni.com/support
