Multifunction DAQ
9174 triggered pulse output and analog input sync
 i have a 9174 cDAQ with a 9215 analog module and a 9401 module. I wonder if this configuration is suitable for my purpose : a extern digital trigger is sent to the system to trigger a analog input task, trigger a pulse generation, with another counter counting trigger events. Using two counters on 9401, it seems i have no terminal left to input my trigger signal. The DAQmx trigger vi doesn't show the counters inputs in the signal list ; and if i select a PFI line, an error says that the line is already in use...Do i have missed some obvious solution ? Do have i to change my 9401 to a 9402 ?
Thanks for any help,
Vincent
Vincent
(4,074 Views)
Accepted by topic author VdG
Hi Vincent,
So it sounds like you need a single line to be used as an input for trigger events, and another line to be used to output a pulse generation.  This should indeed be possible, since the 9401 has 8 lines that are nibble configurable (i.e. lines 0:3 could be configured as inputs, while lines 4:7 could be outputs, or vice-versa).
However, one big caveat with the 9401 is that the lines should be reserved before either task is started.  This is a limitation of how the line direction is implemented in hardware, and is a common issue that customers run into when using the 9401.  Explicitly reserving your tasks before starting should fix the behavior if this is indeed what you are seeing.
Best Regards,
John Passiak
(4,062 Views)
Thanks John,
    i didn't know about the reserve function...and i don't get the error anymore !
Vincent
Vincent
(4,040 Views)
