03-10-2020 06:13 AM
Got the above screen on boot up several times on a cDAQ running Windows embedded 7; did not get expected windows screen. After several attempts of power off than on and pressing reset button, windows screen with application icon finally appeared. What does this mean? 😧
03-17-2020 10:53 AM
It looks like i've the same problem; i found this article to repair / re-install windows 7e
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000001DkdeCAC&l=en-US
But now i'm stuck in the re-installing part : -(
03-17-2020 07:53 PM
Seems that your controller is not able to POST successfully, I am inclined to advice you to contact your local NI representatives to have it repaired.
You may try to get into the BIOS to see if the harddisk/RAM is properly detected if you'd like to investigate more.
03-18-2020 05:39 AM
Do you believe both screens are indications of the same problem? My issue (top screen) is that it displays the National Instruments screen with LOGO. The bottom screen depicts a "Windows Embedded 7 Standard" screen. Is there possibly an error log somewhere that I could send to NI, or possibly some type of Scan disk tool to determine any drive issues? The system is now working correctly but I should think it will happen again? Thanks!
03-18-2020 09:01 AM
I had your problem first and i tried to boot with an external medium, after a few restarts he enters the reinstalling-mode from my DVD or USB. But it gets stuck there.
I've also tried to restart a 10 times without external boot without succes
03-18-2020 07:36 PM
I am not sure about that to be honest, as a system that is unable to POST could be due to multiple reasons.
