04-12-2006 06:43 AM - edited 04-12-2006 06:43 AM
Message Edited by Alexander M on 04-12-2006 06:45 AM
04-13-2006 10:31 AM - edited 04-13-2006 10:31 AM
Message Edited by markwysong on 04-13-2006 10:31 AM
04-18-2006 04:15 AM
04-18-2006 07:39 AM
Aha. This sounds like you've got NI-MAX installed, but somehow your NI-DAQ (the software that communicates to your hardware, and is the software layer that LabVIEW or whatever your GUI program uses to talk to your hardware) software isn't loaded or recognized at the moment.
I would go to Start -> Settings -> Control Panel -> Add/Remove Programs, and remove NI-DAQ and NI-MAX programs from your PC. You can download the current version of NI-MAX from NI's website, and it will contain NI-DAQ (traditional) and NI-DAQmx with it. Install this on your PC, and that should solve the problem.
NI-MAX is just a nice wrapper around NI-DAQ, with a few perks to it, like showing software versions, etc. If NI-MAX doesn't have NI-DAQ installed, or there is a problem with it, it will do exactly what you just described: it won't have the tree showing hardware in your system, virtual channels, etc, etc.
Mark
06-09-2008 04:10 PM
Dear Mark Wysong,
I am an artist working with LabView on a painting machine. I need a little one on one time with a LabView expert to get through problems I have. The forum would be great but my problems are so simple I cannot even find solutions in the many manuals. My latest problems are taking an image, making an array and then performing simple math on the pixels. I am in the process of moving from RoboLAb to LabView. I spend so much time just studying and moving parts from other programs around, there has to be another way. tomlohre.com
