Multifunction DAQ
6034e cause my windows 2000 PC crash.
After I installed NI PCI-6034e on my PC it crashes during the operative system initialization.
On my PC I installed LabView 6.1 before NI PCI 6034e.
(3,132 Views)
Did you install NI-DAQ before inserting the PCI-6034e?
Ben
(3,132 Views)
Yes, I've installed LabView 6.1 and NI-DAQ 6.9.2 before inserting the PCI-6034e.
(3,132 Views)
Hello;
The best way to go about that is to completely uninstall Labview, shutdown your machine and remove the board.
Then, install only NI-DAQ on your machine. Shutdown the computer again, and put the hardware back in.
Run MAX and test the resources of your board. If everything is ok, install Labview, however, choose the custom installation and unselect NI-DAQ from the driver list.
You should be good to go after that.
Hope this helps.
Filipe A.
(3,132 Views)
Contact NI support,
The board may be bad.
Ben
(3,132 Views)
After doing what Fillpe recomends.
Ben
(3,132 Views)
