Multifunction DAQ
6010 witch NI DAQ i should choose
hi,
6010 witch NI DAQ I should choose ?
 I use CVI 6.0 windows2000, i think  : NI DAQ traditionnal 7.4.1 , but i am not quite sure
thanks
(2,869 Views)
Hi Mekhatria,
The PCI-6010 support the DAQmx drivers. So, I strongly recommend that you download the latest version (8.3) and use it for programming your application.
It's easiest to program with this newer drivers. However, if you really want to use the traditional DAQ drivers, 7.4.1 is the good one!
Have a good day,
BRAUD Jean-Philippe
Field Sales Engineer - Nord et Centre France
LabVIEW Certified Developper
(2,850 Views)
Hi Mekhatria and BRAUD,
PCI 6010 is not supported by Traditional DAQ Drivers. ( see this Link   )
You only have to use DAQmx Device Drivers
Dev
Message Edited by devchander on 10-31-2006 03:08 AM
(2,848 Views)
Hi all,
thank u all, this bother me a bit, if 6010 is not supported by traditional DAQ, and CVI 6.0 is not supported by DAQmx, !!!!
(2,842 Views)
Yes that is true! Smiley Sad
Probably you could use this upgrade advisor as an option
(2,822 Views)
