Hi John,
There are two output configurations with the PCI-4461, differential and pseudo-differential. In pseudo-differential mode, the output is grounded to the chassis via 50 Ohm termination (see the
DSA help for the output connection diagram). Is it possible that you are seeing noise in one mode but not another? Make sure you are measuring the signal at the 4461 to make sure the noise is internal and that it is not being induced in your cabling.
Tying the chassis to to signal ground would bypass the 50 Ohm resistor. This would essentially create a single ended signal, however if your chassis has any possibility of being at a different ground potential from your external connection, this could cause a ground loop. Also, impedance matching can be important to prevent signal reflection. The 50 Ohm impedance is one of the standard BNC impedance levels. Bypassing the 50 Ohm resistor by tying your channel to chassis ground could result in mismatched impedances and signal distortion due to reflection.
To address the power-up noise, you are correct that there is not a configurable power-up state. You could however use relays to disconnect the outputs until your task begins and a voltage is being driven.
Jennifer O.
