I'm using DAQ card 6071e, Delphi 6 to program my application. It was working fine in driver 6.6, but not in 6.9. I wrote a simple program, find out that when I called SCAN_Start, it will call the callback function couple times then crash. I only want the callback function once. 6.6 will only call the callback function once, but 6.9 call the callback function couple time. Code on below:
unit TestDAQ;
interface
uses
Windows, Messages, SysUtils, Variants, Classes, Graphics, Controls, Forms,
Dialogs, nidaq, nidaqcns, StdCtrls, OleCtrls, CWDAQControlsLib_TLB;
type
TForm1 = class(TForm)
InitialButton: TButton;
procedure InitialButtonClick(Sender: TObject);
private
{ Private declarations }
intDevice1: i16;
intDevice2: i16;
intNSamples: LongInt;
ptrBuffer1: pi16;
ptrBuffer2: pi16;
intChanVect: pi16;
intGainVect: pi16;
outchanvec: pi16;
ptrOutWave: pi16;
intOutWaveLen: u32;
public
{ Public declarations }
procedure CreateChannelVec;
procedure CreateGainVec;
procedure OutputStimForDAQInitialization;
end;
procedure DAQInputFinishedCallback(handle : HWND; msg : UINT; wparm : WPARAM; lparm : LPARAM); stdcall;
var
Form1: TForm1;
CalledTimes: Integer;
implementation
{$R *.dfm}
procedure TForm1.InitialButtonClick(Sender: TObject);
var
status1: i16;
status2: i16;
begin
CalledTimes := 0;
intDevice1 := 1;
intDevice2 := 2;
CreateChannelVec;
AI_Configure(intDevice1, -1, 0, -1, 0, 0);
AI_Configure(intDevice2, -1, 0, -1, 0, 0);
intNSamples := 2000;
ptrBuffer1 := SysGetMem (32 * 2 * intNSamples);
ptrBuffer2 := SysGetMem (32 * 2 * intNSamples);
CreateGainVec;
try
DAQ_Clear(intDevice1);
status1 := Set_DAQ_Device_Info(intDevice1, ND_DATA_XFER_MODE_AI, ND_UP_TO_1_DMA_CHANNEL);
if (status1 <> 0) then
ShowMessage('TDAQInterface.InitAnalogIO: Problem with Set_DAQ_Device_Info1 on device1 - status = ' + IntToStr(status1));
status1 := Config_DAQ_Event_Message(intDevice1, 0, nil, 0,0,0,0,0,0,0,0,0);
ShowMessage('TDAQInterface.InitAnalogIO: Problem with Config_DAQ_Event_Message clear on device1 - status = ' + IntToStr(status1));
status1 := Config_DAQ_Event_Message(intDevice1,1,'AI1',2,0,0,0,0,0,0,0,u32(@DAQInputFinishedCallback));
ShowMessage('TDAQInterface.InitAnalogIO: Problem with Config_DAQ_Event_Message callback on device1 - status = ' + IntToStr(status1));
status1 := Scan_Setup(intDevice1, 32, intChanVect, intGainVect);
ShowMessage('TDAQInterface.InitAnalogIO: Problem with Scan_Setup on device1 - status = ' + IntToStr(status1));
except
on EDAQStatus:Exception do
begin
raise;
// ShowMessage(EDAQStatus.Message);
end;
end;
end;
procedure TForm1.CreateChannelVec;
var
chan: pi16;
i, j: Integer;
begin
intChanVect := AllocMem (2 * 32);
chan := intChanVect;
for i := 0 to 3 do
begin
for j := 0 to 7 do
begin
chan^ := i * 16 + j;
Inc (chan, 1);
end;
end;
end;
procedure TForm1.CreateGainVec;
var
gain: pi16;
i: Integer;
begin
intGainVect := AllocMem (2 * 32);
gain := intGainVect;
for i := 0 to 31 do
begin
gain^ := 10;
Inc (gain, 1)
end
end;
procedure TForm1.OutputStimForDAQInitialization ();
var
status, status1, status2 : i16;
count : u32;
scanTimeBase : i16;
scanInterval : u16;
freq: f64;
begin
// reset the card circuitry
DAQ_Clear(intDevice2);
try
freq := 20000;
count := 32*intNSamples;
status := DAQ_Rate(freq, 0, @scanTimeBase, @scanInterval);
if (status <> 0) then
ShowMessage('TDAQInterface.OutputStimAndRecordInput: Problem getting the DAQ_Rate - status = ' + IntToStr(status));
status1 := SCAN_Start(intDevice1, ptrBuffer1, count, 1, 1, scanTimeBase, scanInterval);
ShowMessage('TDAQInterface.OutputStimAndRecordInput: Problem with SCAN_Start on device1 - status = ' + IntToStr(status1));
except
on EDAQStatus: Exception do
begin
//ShowMessage(EDAQStatus.Message);
end
end
end;
begin
Inc(CalledTimes);
ShowMessage('Call Back called ' + IntToStr(CalledTimes) + ' times.');
end;
end.
I wonder is it the default of DAQ is now set to continuous aquiring?
Thank you,
Donald
