Multifunction DAQ
4w Resistance Measurement with NI cRIO-9075 and NI-9219
Hello everyone. I am new at this. I have NI cRIO-9075 chasis and NI-9219 module.I looked around but couldnt fing proper source about this, can anyone help about data monitoring and acquising with 4w resistance measurement? Which softwares should i use, what should i do with these softwares etc.
Thanks for your helps.
(1,564 Views)
in addition to LabVIEW you need the LabVIEW Real-Time Module and preferable the LabVIEW FPGA Module.
Keep in mind that the cRIO-9075 is fairly old and is only supported up to LabVIEW 2019 SP1 !
Datasheet NI-9219
Regards, Jens
Kudos are welcome...
(1,545 Views)
