07-12-2006 12:15 PM
07-13-2006 10:11 AM
Hi Earl
I'm not sure if I'm answering your question, but will give it a shot. My vi was written several versions of LV ago and it is currently running on LV7.1. I am using a PCI-6070E for analog output of a generated waveform. I first call AO Config.vi and input channels 0,1. I can then input a 2D array to AO Write.vi and have the waveform output on channels 0 and 1 with no other array manipulation. I would guess the same would hold for input, just using the same procedure using AI vi's. Hope this helps.
Paul
07-13-2006 04:43 PM
07-14-2006 05:44 AM
My pleasure Earl. Hope I played some small part in helping you figure it out.
Paul
