Multifunction DAQ
2 Channel ADC 2 Channel DAC @ 14 bit Resolution with ~1 GS/s Sampling Rate
Hello all,
I am in need of a single DAQ board capable of ADC and DAC with 14-bit resolution. The channels should be processing at around 1 GS/s. The board itself should be interfacable with a PCIe slot on a motherboard. I have found solutions, but all of them are either way overkill for my purposes (16 channels) or too low bit resolution. Any ideas on which products meet my requirements or where I could find a board that meets these requirements? Thank you for your time.
     Keeegan Lorenz-Ochoa
(226 Views)
1 GS/s at 14‑bit pushes you out of “DAQ” territory and straight into “digitizer / AWG” territory.
You won't find any product with both digitizer and AWG in a single card. You should consider looking at two separate digitizer and AWG cards.
https://tmesystems.net/
(195 Views)
You may get a better chance finding suitable Digitizer and AWG separately from Spectrum Instrumentation.
Santhosh
Soliton Technologies
(171 Views)
