06-16-2011 09:06 AM
Greetings from Argentina!, I'm using a NI USB-6218 to mesure 16 analog signals from floating surces, in differential mode. I have a practical problem, in order to avoid erratic results I must use 2 bias resistors to Ai GND for each signal, that means I need 32 resistors!???, We chose this ADQ device because we needed a compact adq system but using all this resistors si not practical at all. Do you have a simpler solution?, Is there any conexión accesoire that includes the resistors to GND?
Thanks and excuse my english...
Solved! Go to Solution.
06-16-2011 11:15 AM - last edited on 04-24-2024 01:35 PM by Content Cleaner
a few of these will keep it nice and tidy
06-16-2011 01:06 PM
Thank you very much!, the faster answer ever.
06-16-2011 01:41 PM
NI could do a better job of promoting them! they are pretty sweet
