le 05-05-2006 08:21 AM
le 05-08-2006 04:29 PM
Hi jrs2,
See the following KnowledgeBase article:
Specifications and Manufacturers for Board Mating Connectors
The part you are interested in is actually manufactured by AMP (part 787169-9). The AMP website will have more detailed specs on that specific part, and they should have the dimensional drawing you are looking for.
Justin M.
le 08-24-2007 03:22 PM
le 08-27-2007 07:09 PM
Hi RawoChip,
If there is a specific NI product that uses the 100-pin male connector you are
referring to I'd be more than happy to find the part number for it. If not,
then I suggest that you contact AMP via their website in order to find out more
information on the part in question.
le 09-10-2007 09:23 AM
le 09-11-2007 08:36 PM
le 09-19-2007 09:16 AM
The screwlocks are using to secure the cable to connector.
I found the part number for the Screwlock or Jackpost for the 100 Pin connector. The part number is 749087-2, Tyco is the manufacturer. I bought the screwlocks from Digikey. You can use the same screwlocks for the 68 pin connector 2-174225-5.
le 09-25-2007 02:33 PM
le 09-26-2007 10:53 AM
le 09-26-2007 11:00 AM
