04-09-2010 06:16 PM
Well no worries about the image and camera we have more the lots of Gb in memory back up
Hence we even can go to 1.000.000 imamage´s if we want
so no streaming problems here and no delays
The problem is capture the image in flight and keep it focus at all time´s
04-12-2010 05:59 PM
Hi cees10,
The issue is not whether the camera can stream the images or if there is enough memory to hold the images. The concern I was trying to point out is that the larger the image is, the more time it will take to process the image to find the arrow. You can think of an image as a large matrix of values. The larger the image, the larger the matrix and the more time it will take to run calculations with it. Since your experiment will be over in 0.1s, the time it takes to process these images is essential for a fast reaction time.
Again, I want to point out that you said that your camera acquires images at 30 frames per second. This basically means you're only going to get 3 images during the 0.1s, which means the camera only sees the arrow in three different positions. I'm guessing that you would want more images of the arrow while it is in flight. Because of this, you may want to think about using a camera that can capture more frames per second.
04-12-2010 06:24 PM
Again, I want to point out that you said that your camera acquires images at 30 frames per second. This basically means you're only going to get3 images during the 0.1s, which means the camera only sees the arrow in three different positions
Yes i know we can capture 30.000 frames a second.
and becuase of this my worries is indeed how we track the arrow in 0.1 of second in 3000 frame's (as the calc is needed to calc its position as you pointed out)
thats the biggest problem here!
Thats why my question was to have ideas to solve this problem
04-13-2010 06:33 PM
Hi cees10,
As I've mentioned previously, to avoid trying to design a control system that relies on only 3 images, you may want to consider moving your camera back such that you capture the entire path of the arrow you are trying to follow. You've indicated that this might be a suitable solution for you.
Another idea would be instead of trying to capture everything on one camera, you might want to consider using multiple cameras along the path of the arrow. Then sync up the images afterwards in the post-processing.
