In the test bed, we are testing a brushless DC motor and a load motor generates torque to the test motor. The test motor is running with torque control scheme. They were connected together and I measured the torque signal to feedback the signal and control it. However, I just realized it only control when the torque was static. If I commanded a certain torque value (in this case, counts command), it kept generating that value. However, it did not generate the same torque in different position. I heard NI motion controller could develop torque values by mapping the torque signal with encoder signal. If it's true, the torque generation based on analog feedback, also, needs constraint by rotor position, right? W
hen I turned on the load machine with constant speed (50 RPM), the torque from the test motor did not provide the constant torque that I commanded. It generated the fluctuated torque values. This means the max torque was generated at one point and decreasing by rotating the shaft and increasing the torque. Keep going in this way. Could you please tell me if this is the correct response when we are using analog torque feedback?
Thank you.
