02-23-2006 03:32 AM
02-23-2006 03:55 AM
02-23-2006 04:14 AM
02-23-2006
04:22 AM
- last edited on
11-17-2025
08:58 AM
by
Content Cleaner
Here is a document that describes the tuning process of a DC motor with NI motion control boards. As you don't have a motion control the document is not a perfect fit for you but it describes very well the basics of PID tuning in general.
From my experience I can tell that most autotuning algorithms work only fine for a very specific control environment so I prefer manual tuning as this results typically in a better system behavior.
Jochen Klier
National Instruments Germany
02-23-2006 04:51 AM
02-23-2006
05:02 AM
- last edited on
11-17-2025
08:59 AM
by
Content Cleaner
The best option for you would be to use the NI SoftMotion Development Module as it provides all the features that you need. General information about LabVIEW Real-Time can be found here. Please follow also the related links on this site.
It depends on your motor type and general application needs if you can use the 6221. The SoftMotion Module provides code examples for both, DAQ boards and RIO devices. Just some weeks ago I have used M-Series boards to control two synchronized DC motors with a loop rate of 4 kHz so your 6221 might be sufficient.
Jochen Klier
03-19-2006 11:40 PM
Mr.Jochen ,
sir ,you said that some weeks ago you have used M-Series boards to control two synchronized DC motors with a loop rate of 4 kHz , please mail me the vi of that application . was it in real time labview , i am able to operate the PMDC motors in labview itself i.e to switch on and off , run in forward and reverse mode , brake it , but to control the speed of the motor with pulse width modulation , the average voltage applied to the motor is flickering and is not stable. i am using A3949 full bridge motor driver circuit for my application i.e closed loop speed control of two pmdc motors with pxi 1010 system and labview. please suggest me on this , i have tried the same with the real time labview also , but there was hardly any change from the latter one .
please suggest me on this and i request you to send me the vi for the appication which u have developed for a reference .
thanking you
deepak
03-20-2006 02:23 AM
