08-30-2005 08:28 AM
Hello!
I am using the motion control NI7334 and I need the breakpoint output to trigger my measurements.
In a quite simple program I re-enable the (modulus) breakpoint each time it occurred. The fastest repetition rate I could generate to enable the breakpoint was about 110 Hz, with higher breakpoint frequencies it becomes irregular, means I don't get all breakpoints. I'm worried if it becomes even worse when my program will be more complex. These low rates for re-enabling the breakpoints are a problem of the labview-code, of windows xp or of the communication between software and PCI-board?
08-31-2005 01:59 AM
