03-11-2009 02:33 PM
On axis 2 of a UMI-7764, the inhibit out is constantly active, disabling the third party motor driver. I have axis 1 configured identically in MAX and it works just fine with identical hardware. I have traced the problem back to at least the UMI if not the PCI-7330 controller card. INHOUT2 is constantly on -- either high or low depending on the polarity switch. MAX will still allow the UMI to generate control pulses for Step and Direction so long as it thinks that the axis is not killed. I am not using encoders or limit switches at the moment.
Settings are as follows:
Enabled, no feedback, step & direction output, active high polarity, disabled limit filters and switches, disabled software limits, and enabled inhibit out active high.
Axis 1 has the same settings, and works fine.
Solved! Go to Solution.
03-11-2009 04:12 PM
03-11-2009 05:15 PM
