Hello Vinny,
Since you are using a DC motor, all that you have to do to change the speed of the motor is use an analog output line from your DAQ card and increase its voltage value from zero (stop) to five volts. There are two ways to do this. You can use a sawtooth waveform (see Functions >> All Functions >> Waveform >> Analog Waveform >>Waveform Generation). You can specify the amplitude and frequency of the waveform, as well as the number of points to generate. Try looking at the Function Waveform Generation example VI that shipped with LabVIEW to see how that waveform function works.
Another way to do this might be to use a for loop where you increase the value with each iteration of the loop. You can place a Wait Until Next ms Multiple VI inside of the lo
op to specify how many milliseconds each loop iteration will take.
Let me know if you have any further questions on this issue.
Scott Romine
Scott Romine
Course Development Engineer
