Hi all,
as I am just starting with Motion Control 7334 I only want to give out the steps signal in an open loop mode without controlling it. In the example of the "Simple One Axis Move" I can load a target position but I can't find a function (icon) to load the number of steps.
First I thought, target position and number of steps could be the same, if there isn't a feedback. It works, if it is not connected to anything (I use the Universal Motion Interface (UMI-7764)), means, I get no error message. But connecting it with this device it doesn't work.
Do I need a feedback? In the configuration I found, that I can set the primary feedback to "none". Is that the way? (It doesn't work neither.)
Thanks ...
