Motion Control and Motor Drives
compatibility between NI-MOTION and NI-DAQ using Visual basic 6
Hello to All,
I'm using two boards in my pc, a 6014 for analog input/output, and a 7334 for move a 4 axes device.
The operative system is Windows Xp, and I use Visual Basic 6.0.
I install the NI-DAQ and the NI-MOTION but, after install the NI-MOTION,
the Visual Basic starts to fault.
Every time I try to access to the 6014 board, I get the following error:
Err 10459.
"The NI-DAQ DLL could not be called due to an interface error".
This error happen if I use the NI-DAQ 6.9.3.
So I've removed that version and I've installed the 7.4.x, without any success result.
With this version I have the following error: "nidaq32.dll Not Found".
Do you have any idea?
(3,169 Views)
