I'm trying to setup a system that needs to deliver an adjustable pressure between 2250 psi to 3750 psi and at an adjustable rate of 1mm/second to 5mm/second.
I'm trying to figure out if this is possible with an Electromechanical actuator or any other system .I'm new to the field of actuators and apologize for any errors in terminology or units.
Would greatly appreciative any help and suggestions/ wisdom on the idea.
Warm wishes to all,
Vik
