Motion Control and Motor Drives
What is the required hardware to control AMC servo amplifier model 30A20AC?
Hi everybody,
What is the required hardware to control "Advanced Machine Controls" servo amplifier Series 30A-AC, model 30A20AC?
The interface hardware should connect to a laptop, and run in real-time.
Tnank you
(3,471 Views)
Hi Nkhbeik,
I went to ni.com/motion >> choose NI Motion Hardware.  I then filtered out the hardware that did not support Real-Time by clicking on Real-Time on the left hand side of the page.  There are a number of results returned.  Depending on how many axis you need, you can filter the results further.  Any of the results can be used with the appropriate connector, either a cRIO chassis (for the 9505), a PXI Chassis (for PXI formfactor), or a PCI Extension device for a PCI card.  I hope this helps!
Kristen H.
Message Edited by Kristen H. on 06-08-2009 01:22 PM
(3,462 Views)
