03-23-2010 09:41 PM
I am currently working on a robotic project which involves a locomotive autonomous robot.
I have a few DC motors attached to the robot. One of them spins at about 7000rpm. As a result it causes massive vibration.
Thus I would like to find out how to measure the vibration and plot its frequency response to obtain the maximum vibration frequency.
This would help me in purchasing the correct vibration dampener.
Can anyone suggest how I can accomplish the above?
Thanks.
03-24-2010 04:02 AM
03-24-2010 05:39 AM
03-24-2010 08:29 AM
To measure vibration, you will want an accelerometer (or two) and signal conditioning for the accelerometer. The NI 9234 is the most cost effective data acquisition device for accelerometers, though we do offer signal conditioning for standard data acquisition boards.
What NI hardware are you using now?
03-24-2010 10:25 PM
I currently do not have any hardware to measure the vibration. I just need to conduct the measurements a few times. Thus I don't need dedicated hardware for it. Simple basic setup/equipment will do the job in my case.
Can you recommend other ways?
03-27-2010 04:33 AM
Oscilloscope cannot just hook up to accelerometer.
You really need to build a signal conditioning circuit, and if you wish to read it with LabVIEW, you can try finding your scope's instrument driver from ni.com/idnet.
So you've two options, do hard work on circuit or investment on 9234.
