Variate velocity according to position
Hi all,
I'm now using PCI7330 with P70530 to control the stepper motor CTP10XXX10.
My goal is to let the motor run at certain speed as a function of its current position. Is this possible to read (position) from and write (velocity) to the drive at the same time?
-chen
Message 1 of 11
(7,093 Views)
I think I need a servo motor...
Message 2 of 11
(7,091 Views)
What leads you to believe you need a servo?
Message 3 of 11
(7,052 Views)
Sorry for the double post, but I was also wondering if you have an encoder on the stepper, or are you just wanting to rely on it's positional feedback?
Message 4 of 11
(7,050 Views)
Christopher, many thanks for your reply. Yes, I just need to ensure the position is correct.
Do you think a real time module is necessary here? Cause 7330 seems can only output trapezoid shaped wave form for velocity, i.e. before the motor stops, I can not do anything to it. Or do you have any other suggestion? Please help, thank you again.
Message 5 of 11
(7,041 Views)
Sorry, I forgot to mention I will buy one with encoder...
Message 6 of 11
(7,034 Views)
I'm still looking in to this, but in the interim you might check out the joystick example (joystage.vi) located in the example finder. I believe it accomplishes something similar to what you are after.
Message 7 of 11
(7,016 Views)
Christopher, thanks again for your time.
You may see the subvi called "Start Motion.flx" with a green trangle as its icon.
Once it's running, the motor will start to run, during which time I can not do anything to the motor.
Modification of it seems nontrivial to me.
Message 8 of 11
(7,010 Views)
If you are wanting to base your velocity on absolute position, it sounds as though a countour move might be ideal for what you are trying to accomplish. More on that here: http://zone.ni.com/reference/en-XX/help/371093K-01/mclvhowto/movecontourinfo/
This tool automatically creates a spline for you, blending a series of pre-determined moves in to one smooth, continuous operation. Does that sound like something that would resolve your issue?
Message 9 of 11
(6,939 Views)
Thanks Christopher, I was thinking about that, but contour move is not what PCI 7330 can do. I am looking for other modules now.
Message 10 of 11
(6,933 Views)
