04-19-2006 03:36 AM
04-20-2006 10:48 AM
Shane,
There should be a way around your problem. I am a bit confused regarding what is actually going on. I have a few questions...
Are you switching your feedback on the fly or are you killing your axis before switching your feedback?
You said...
"By doing this the analog feedback is only offset by a maximum value equal to the peak to peak noise on the ADC channel - but an offset (may) still exist which can be significant."
Can you clarify what you mean... What is causing the offset? the noise? Isn't the noise always effecting the system?
Below is what I think I undestand about your problem...
You have two types of feedback (position/encoder and force/analog/strain gauge), you use the position feedback and occasionally reset the position of the encoder. This changes the primary feedback position to 0. Then you switch over to the analog feedback and your primary feedback position remains at 0, you would like the primary feedback position to not change and rather always be referenced to the no load voltage of the strain gauge.
Tell me if I understand you correctly.
One thing I don't understand, I would think that reading the ADC channel before doing a reset and then making sure you reset the position to the desired position would fix the problem (this sounds like your current workaround). I guess I don't understand what is not working when you do this?
I need some clarity.
Lorne Hengst
Application Engineer
04-20-2006 07:23 PM
04-21-2006 07:01 PM
Shane,
Bad news. I talked to our R&D department about your issue. Basically, there is no way to directly set the reset position and that your only solution is to reduce the noise on the strain gauge. Can you implement an external lowpass filter to reduce the noise you are experiencing?
I wish I had better news. Sorry,
Lorne Hengst
04-25-2006 07:59 PM
07-27-2018 12:22 AM
HI
I am facing some issues after upgrading to LabView 15 , i am using Pxi-8840 and motion controller 7350.
some of the VI's as stated below are missing.
1) Motion error handler.flx
2) reset position.flx
3) Initialize controller.flx
I had installed NI-Motion 14 ,18 and 8.1 can you suggest how can install missing VI's.
