12-13-2007 10:54 AM
12-14-2007 06:12 PM
12-17-2007 06:29 AM
Evan,
Thanks for the response, I have created a similar initialization. I also have used the initialization in the MAX. I did some digging in the MAX and found my user error. Under Motion I/O settings I had "Inhibit Input Settings" disabled. After enabling I no longer had the "disable" Indicator issue.
Thanks for your help!
12-18-2007 09:36 AM
10-13-2020 05:18 PM
We are running some old stuff donated to us at the university.
Have the same exact issue and are trying the fix suggested here (depicted in "PU Reset VI Screenshot.JPG 36 KB".
The "Clear Power Up Status" needs the "Board ID" as input. Where can this be found?
Thanks!
10-13-2020 05:23 PM
We do also have the same Motion I/O Setting as described above:
" I did some digging in the MAX and found my user error. Under Motion I/O settings I had "Inhibit Input Settings" disabled. After enabling I no longer had the "disable" Indicator issue. "
However we cannot switch from "Disable" to "Enable" the lowest selections in the popup are greyed thus not allowing any change...
Any idea how to make this selectable again?
Thanks!
08-05-2021 12:47 PM
hello,
i have resolved this issue many-many years ago, but now i have also been facing this or similar again. 😕 🙂
For UMI disable-->enable (only disable LEDs red), i am not exactly sure, but something physsical connection Limitswith or enable or else needed on feedback or control.
At this moment i have similar but more tricky issue: interlock LED is red. (inhibit all is not REd)
I have checked the host 5V by disassembling UMI and measure pin50 on PCB.
Maybe the current is not proper due to HW ageing, but i do not supposed this.
I am in-crazy 🙂 do not beleive it is not norking again.
Very over-complicated this i think.
regards,
Endre
