I am using PCI-7344 to control a servo motor. Based on initial
evaluation, there appears to be some transition time when I tried to
change from one velocity to another instantaneously. For example,
when changing from 20 rpm/s to 30 rpm/s, I saw the velocity goes from
20 rpm/s down to 0 rpm/s before it rises back to 30 rpm/s. The total
transition time from 20 rpm/s to 0 rpm/s to 30 rpm/s takes ~500ms. Is
there any way to eliminate or at least minimize the transition time?
And maybe smoothing out the transition?
Our application may require a change in velocity as often as once per
second. (A new velocity is determined by a controller in real-time)
Thus, the transition time seems to have a signif
icant effect on our
overall experiment duration. (Note: the acceleration was left at the
default value)
Any comments or advices are welcomed.
Vanessa
