06-14-2006 07:48 AM - edited 06-14-2006 07:48 AM
Message Edited by LVB on 06-14-2006 08:49 AM
06-14-2006 10:48 AM
For the actuator, have you looked into Industrial Devices Corporation's line of electric cylinders? Long stroke, high torque actuators. You can outfit them with an encoder and limit switches to motior position.
Someone else may chime in with required NI motion control hardware
06-15-2006 12:06 PM
03-13-2017 02:14 PM
Dear Allen_h, I hope you can help me with my problem:
I am trying to connect the UMI-7774 (previously connected to a PCI card 7334 within a PC with windows XP) to a gecko driver g203v, but I cannot manage to move a stepper motor.
I have tested the driver and the motor with the PWM signal from the PCI card and it worked, for frequencies from 4k to 33k of the PWM.
When I measure the output signal from the UMI device, I get 5 volts amplitude and a normal step signal, but when I connected to the Gecko driver the signal is 1.5 volts amplitude.
The Gecko driver requires a source configuration, whilst the output of the UMI device is sink open collector. I tried to connect the step signal directly to the driver but it did not work, then I connected the UMI ouput through a resistor to 5V source (sink configuration), but it didn´t work.
Does anyone knows if the UMI device have to be connected only with NI motors drivers?
or can anyone advice how to solve the problem?
Best wishes,
Victor
