I use SoftMotion for a slightly different application, but here it seems, that Labview tries to send a setpoint parameter to the motor, which cannot act, because either the power voltage is not connected or the axis has not been hardware or software enabled yet.
WIth some drives, you can connect via a ethernet service port and use the corresponding software to see whether the drive is Software / Hardware enabled. In any case be carefull as the motor can start moving at high speed when activated.
