Motion Control and Motor Drives
Replacement for PXI-7344
Need recommendation for the replacement of PXI-7344 (last order date is end of Sept.).
Need 4 axis step motor control.  For 32 bit LabVIEW 2014 or later.
NI product preferred.
TIA.
George Zou
(3,178 Views)
Hi
(3,146 Views)
Thanks for reply.
Is there a guideline, example, or tutorial for replace NI-Motion with SoftMotion ?
George Zou
(3,121 Views)
You are welcome.
These platforms are quite different so there is not a direct path for replacing the NI-Motion due to SoftMotion makes the connection and coding much easier and the platform (RIO instead of PXI/PCI) where it works is different
If you have an application already made and you'd like to transfer it to SoftMotion, I'd recommend opening and Service Request as it's quite difficult to assess something like that on here.
PedroR
(3,116 Views)
