I am trying to use a DEVA 004 PC card with Labview to control a motor using a PID controller (using PID toolkit on Labview). I can create the virtual controller (using simple PID example found on the NI website), however when i try to run a DEVA llb file, to create IO parameters etc. it uses the vimot32.dll file (supplied with DEVA card), and has to reference to the kernel32.dll file located in the Windows/system directory. However, there seems to be a fault with this file, as i continually get an error message. Any ideas as to what i'm supposed to do, cos I am not a computer whizz.
Cheers
Paul Nicholson
