Have a pxi-7344 board running under RT.
When axis 1 is moved in closed loop mode with encoder feed back(Absolute move) in the positive direction an output of +4 Volts is on the DAC.
When it is moved in the opposite direction -4 Volts is on the DAC.
For Axis 2 with the same setup and same commands the positive direction outputs 9 volts while the negative outputs 0 volts.
I'm still getting the full 10 volt range from both joints.
Reformatted the PXI HDD and re-setup all the axis, cards, etc. Copied the same startup.exe file to *\ni-rt\startup\ and now Axis 2 outputs the +/- 4 Volts.
Are there any thoughts on what could have caused this to happen? RT VI's I should run when initializing the joints to reset the system?
It seems like a really wierd error. Not sure how I can fix it without reformatting the Hard drive.
