12-05-2009 03:30 PM
I have a PXI crate with LabVIEW 2009 and a PXI-6052E board in the crate. I cannot hook the computer to the internet and was wondering what is the fastest way to get basic VI examples for the PXI-6052E. I just want a couple of the analog inputs to be read in.
Kevin
12-07-2009 03:41 AM
Hi Kevin,
the PXI-6052E is supported by the NI-DAQmx driver. So if you can find the board in MAX, the driver is installed correctly and you should be able to run the examples, that are installed in the \LabVIEW\examples directory (use the example finder in MAX).
If NI-DAQmx is not installed yet, you need to do this (e.g. by using an USB DVD drive).
Jochen
