Motion Control and Motor Drives
PCI7344 and 3 servo simultaneously
Using a PCI 7344 and three servos (with LabVIEW). One servo controls RPMs of a turntable and 2 servos adjusting the pitch of the table in two planes all controlled simultaneously. Would I use seperate loops, for the seperate servos? can I write to the PCI 7344 from three loops simultaneously? does anyone know of an example out there? Thanx
Lawrence M. David Jr.
Certified LabVIEW Architect
cell: 516.819.9711
http://www.aleconsultants.com
larry@aleconsultants.com
(1,946 Views)
Hello lmd2,
This particular question has a variety of solutions, depending on what exactly you are wanting to accomplish and what other events are occuring in your program.
To save you some time reading through every possible solution, please call into National Instruments to discuss the issue a little further.
512 795 8248
- Ask to speak to an Applications Engineer in the IMAQ / Motion group.
The task you are describing is possible, I want to make sure that you get the best solution for your application.
National Instruments Applications Engineering
(1,946 Views)
