04-17-2014 07:06 PM
The spec says the PCI-7334 is for windows Windows 2000/NT/XP, is it possible to work in windows 7 or vista? I want to have a try.
Thanks!
04-18-2014 09:58 AM - last edited on 07-19-2024 05:24 PM by Content Cleaner
Hi thitchen007,
It will work with Windows 7 and Vista, you just need the right software. The 7334 uses the NI-Motion software. The latest NI-Motion will work with Windows Vista and Windows 7. These will also work with LabVIEW 2010 and later. You can download the evaluation here: https://www.ni.com/en/support/downloads/drivers/download.ni-motion.html
01-06-2025 07:57 AM
the PCI-7334 is working with Windows 10. Does it also work with windows 11?
Attached the compatibility list, but Windows 11 is missing:
Archived: NI Motion Controllers and Microsoft Windows Compatibility - NI
Thanks and best regards
01-09-2025 06:22 PM
Hi Kuliwer,
NI has discontinued their motion control products since 2019. That's why you won't see any more support for NI-Motion beyond Windows 10.
For support with Windows 11, my company has a motion controller the replaces the NI-73xx series of products. We can support Windows 11 and beyond.
For more info, check here: https://geco-lv.com/emotion.html
BR
John
Add motion to LabVIEW in 30min or less - TENET EMotion
Finding it hard to source legacy NI hardware? Try Extend Test
