01-15-2010 05:04 AM
I am trying to control a third party motor and motor driver (Schneider) with the PCI 7332 in my computer and the UMI 7772 connector block. When I power up the motor, the driver and the UMI7772, the motor has holding torque. The problem is I seem to be unable to give any commands to the motor through MAX. I can´t even kill it to stop the holding torque. I followed the instructions to initialize the PCI 7332 axes through the MAX and it doesn´t show any errors. I did find through a search in the forum that the red Limit Switch LED´s can prohibit the motor movement but I don`t think it should prohibit killing the axis. Also, I can´t understand how the limit LEDs are on since all the limit switches are disabled from the Motion I/O settings. I really need help. Thank you in advance.
01-15-2010 06:35 AM
01-18-2010 02:52 AM
with the information provided it's hard or even impossible to tell what's going on. Could you please provide some more detailed documentation (the drive's data sheet /manual and the wiring between the UMI and the drive)?
Thanks and kind regards,
Jochen Klier
