04-03-2018 04:20 PM
I am try to identify the failure mode or where the error may be occurring in my system. I am using a UMI 7774 board, PCI 7344 motion controller, and a Haydon DSC4020 chopper drive to control three stepper motors. When testing the Axes in MAX, only Axis 4 control port causes the stepper to move in the clockwise and counterclockwise direction. The Axis 1 control port will cause the stepper to only move clockwise regardless of whether a positive or negative relative position is tested. Finally, the Axis 2 and 3 control ports cause no response or move from the stepper. These tests were done using the same settings in MAX for all Axes and using the same stepper drive.
I tested the resting, clockwise move, and counterclockwise voltage of Pin 4 (the CW Step pin) and Pin 12 (the Dir CCW pin) on the the control port. Here are the results:
Axis 4 (fully functional Axis)
Pin 4:
Resting Voltage - 4.96V
Clockwise Move Voltage - 4.83V
Counterclockwise Move Voltage - 4.83V
Pin 12:
Clockwise Move Voltage - 0.064V
Counterclockwise Move Voltage - 4.96V
Axis 1 (clockwise functional Axis)
Pin 4:
Pin 12:
Resting Voltage - 0.029V
Clockwise Move Voltage - 0.025V
Counterclockwise Move Voltage - -0.029V
Axis 2 (non-functional Axis)
Pin 4:
Resting Voltage - 0.048V
Clockwise Move Voltage - 0.046V
Counterclockwise Move Voltage - 0.046V
Pin 12:
Resting Voltage - 0.64V
Clockwise Move Voltage - 4.96V
Counterclockwise Move Voltage - 0.64V
Axis 3 (non-functional Axis)
Pin 4:
Resting Voltage - 0.003V
Clockwise Move Voltage - 0.004V
Counterclockwise Move Voltage - 0.004V
Pin 12:
Resting Voltage - -0.05V
Clockwise Move Voltage - -0.029V
Counterclockwise Move Voltage - -0.05V
I am trying to understand why there is a difference in voltages if they are using the same settings and moves. Would this be caused from a damaged UMI board or from the PCI card? Any help to fix is greatly appreciated.
04-04-2018 04:52 PM
To further narrow down the issue, do you have another UMI or PCI 7344 to test? This could help us narrow down whether the UMI or the PCI is damaged.
Otherwise, you could also measure the pins from the Motion I/O on the PCI card (see page 5-2 of the manual: http://www.ni.com/pdf/manuals/322504b.pdf).
